error404
May 09, 2017Aspirant
ReadyNAS214 with APC UPS pro 550 upgraded to 6.7.1
ok, after the firmware upgrade, my nas will not shut down properly anymore, I set to shut down and the disk lights go off but the flashing blue button keeps going forever the screen says Goodbye , b...
Sandshark
May 09, 2017Sensei
I've had it happen a few times, but never every time. One possibility, I think, is that the OS partition is full and the unit is failing when trying to write the power-down info to the log. An OS upgrade does use working space in the OS partition, maybe that didn't get cleared out properly. Plus 6.7.1 may be a bit bigger. Do you have SSH enabled so you can go in and take a look? mdgm-ntgr may want to take a look at your logs, too.
