kentd
May 09, 2017Tutor
ReadyNAS 516 just upgraded to 6.7.1 and data volume has not loaded
Hi,
I just installed 6.7.1 and on re-boot the primary data volume has not loaded - and suggests removing the inactive volume.
I have two volumes, one of 6 drives in the RN516, this was a raid 6 volume called 'data' it was encrypted, and the usb key has always and is still in the NAS. (no problems rebooting any other time).
The 2nd volume is 5 drive volume in the EDA, called 'eda1', also raid6 and also encrypted. This volume has loaded fine and unlocked the encryption.
/data-0/.timemachine was a subvolume, so a regular deletion didn't work. I removed the subvolume and directory, and now everything is mounted normally.
- mdgm-ntgrNETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- kentdTutorIs there any instructions or link to how please?
- kentdTutor
Last login: Sun Jul 3 18:55:46 2016 from 192.168.7.180
root@KDNAS4:~# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 3.7G 25M 100% /
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 1.9G 4.0M 1.9G 1% /run
tmpfs 960M 1.1M 959M 1% /run/lock
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/mapper/eda1-0 17T 11T 6.0T 64% /eda1
/dev/sdl1 1.9G 917M 969M 49% /media/USB_FLASH_5
/dev/mapper/eda1-0 17T 11T 6.0T 64% /var/ftp/Movie1
/dev/mapper/eda1-0 17T 11T 6.0T 64% /var/ftp/TV2
root@KDNAS4:~# df-i
-bash: df-i: command not found
root@KDNAS4:~# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 490647 653 489994 1% /dev
/dev/md0 0 0 0 - /
tmpfs 491265 1 491264 1% /dev/shm
tmpfs 491265 999 490266 1% /run
tmpfs 491265 25 491240 1% /run/lock
tmpfs 491265 11 491254 1% /sys/fs/cgroup
/dev/mapper/eda1-0 0 0 0 - /eda1
/dev/sdl1 0 0 0 - /media/USB_FLASH_5
/dev/mapper/eda1-0 0 0 0 - /var/ftp/Movie1
/dev/mapper/eda1-0 0 0 0 - /var/ftp/TV2root@KDNAS4:/# du -csh /var/log/*
4.0K /var/log/alternatives.log
1.5M /var/log/apache2
32K /var/log/apt
4.0K /var/log/btmp
4.0K /var/log/dbbroker.log
124K /var/log/dpkg.log
8.0K /var/log/faillog
6.3M /var/log/frontview
0 /var/log/fsck
71M /var/log/journal
12K /var/log/lastlog
56K /var/log/mysql
0 /var/log/mysql.err
0 /var/log/mysql.log
0 /var/log/news
136K /var/log/proftpd.log
2.0M /var/log/readynasd
260K /var/log/samba
224K /var/log/wtmp
81M total
root@KDNAS4:/# du -csh /var/*
0 /var/agentx
68M /var/backups
51M /var/cache
44M /var/cores
5.8T /var/ftp
80M /var/lib
0 /var/local
4.0K /var/lock
81M /var/log
0 /var/mail
8.0K /var/netatalk
40K /var/nuuo
0 /var/opt
9.6M /var/readynasd
0 /var/replicate
4.0K /var/run
4.0K /var/spool
0 /var/tmp
4.0K /var/www
5.8T total
root@KDNAS4:/# du -csh /var/log/frontview/*
140K /var/log/frontview/amazoncd.log
3.0M /var/log/frontview/amazoncd.log.old
1.2M /var/log/frontview/backup
4.0K /var/log/frontview/initrd.log
164K /var/log/frontview/msmtp.log
4.0K /var/log/frontview/password_recovery.log
460K /var/log/frontview/status.log
1.5M /var/log/frontview/status.log.old
6.3M totalOnly apps i currently use are ReadyNAS Surveillance and Transmission.
Most likely it's transmission.
You are ignoring a lot of folders (/usr, /lib, /etc), and it is also possible that the data was written "underneath" a mount point (particularly /apps)
Try mounting the OS partition as /mnt, and then explore /mnt. That will solve the data "underneath" problem.
# mount --bind / /mnt
When done
# umount /mnt
- kentdTutorDone
- jak0lantashMentor
Did you use the mount command given by StephenB?
mount --bind / /mnt
Then look inside it:
cd /mnt du -d1 -h
It will tell you which is the biggest folder, then cd into it and re-run:
cd <big_folder> du -d1 -h
Repeat the operation until there is no more big folder, only the total is big, which means it's big file(s) in the current directory, then:
ls -lhS
When you're finished cleaning up the big files, unmount the temporary bind:
cd umount /mnt
- kentdTutor
ok, here is the big folder ./controlc-wpbackup - this must have been written to here by an internal backup job rather than the data volume.
Last login: Thu May 11 07:58:49 2017 from 192.168.7.26
root@KDNAS4:~# mount --bind / /mnt
root@KDNAS4:~# cd /mnt
root@KDNAS4:/mnt# du -d1 -h
6.7M ./bin
0 ./boot
24K ./dev
12M ./etc
33M ./lib
4.0K ./lib64
32K ./media
0 ./mnt
4.6M ./opt
0 ./proc
24K ./root
0 ./run
10M ./sbin
0 ./selinux
0 ./srv
0 ./sys
4.0K ./tmp
360M ./usr
335M ./var
0 ./home
0 ./apps
2.7G ./data
0 ./eda1
0 ./crypto_LUKS
3.6M ./lib32
35M ./data-0
29M ./frontview
3.6G .
root@KDNAS4:/mnt# cd data
root@KDNAS4:/mnt/data# du -d1 -h
0 ./AmazonCloudDrive
0 ./FamilyPics
237M ./KentandMing
0 ./controlc-orangefix
0 ./controlc-redjungle
2.5G ./controlc-wpbackup
0 ./Photos
0 ./scans
2.7G .
how do i just delete it? - its only a wordpress site backup and can go.
- kentdTutorYes log files have been sent
- jak0lantashMentor
"df -i" is irrelevant on a RN516 as both the data volume and the OS volume use BTRFS.
Does it boot now? Is your data volume blue?
- kentdTutor
Hi, the unit reboots but the primary data volume is still not loading.
Is it because its not md126, or because it is encrypted too? (yes the USB with the encryption key is still in - and hasnt been removed)
