DominicanMacPro
Jan 10, 2020Apprentice
ReadyNASRNDP4000 Just blinking
When I power up my ReadyNAS Pro 4 can see only a blinking "_" on the LCD. No text nothing ... I have 2 brand new 2tb drive The device didn´t showed up in the Network - The RAIDar is also not ab...
Sandshark
Jan 11, 2020Sensei
I don't believe the Pro4 says "ReadyNAS" with just power applied. My Ultra4 does not, while the legacy 6-drive systems do. But it should definately say "no disks" with no drives installed and give you a boot menu. If your Pro4 is still under warranty (since you mentioned RMA, I assume it is), then that is the direction you should move. I doubt you have a lot of time remaining on the 5-year warranty.
- DominicanMacProJan 11, 2020Apprentice
Thank you so much and I was thinking same rma and yeah I still have warranty until some time in 2024 for the hardware
