Blueray3
Oct 18, 2017Guide
ReadySync relocate
Using fw 6.8.1. When I use the ReadyCloud app on a Windows 10 pc to sync a share (folder) on the ReadyNAS to a folder on the PC, it defaults to users\users name\ReadySync. Is there a way to locate ...
Marty_M
Oct 23, 2017NETGEAR Employee Retired
Hello Blueray3,
Unfortunately there is no way to change the location of the setting of the sync with PC process. The backup feature of the app is to backup the folder from PC to the NAS the source is the PC and the destination is the NAS. The sync direction is just one way PC to NAS. Changes made on the sources will be sync to the destination but changes made on the destination will not be synced to the the source.
Marty_M
NETGEAR Community Team
- Marty_MOct 26, 2017NETGEAR Employee Retired
Hello Blueray3,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
