mERGER
Oct 10, 2013Aspirant
Realocating sectors same time each day
Is this normal? (see log below)
Why does it happen at 04:00 every time? Does something happen then?
Is it a "correct" error or just a false positive?
Mon Oct 7 04:00:04 CEST 2013 Reallocated sector count has increased in the last day. Disk 2: Previous count: 93 Current count: 94 Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
Sun Oct 6 04:00:03 CEST 2013 Reallocated sector count has increased in the last day. Disk 2: Previous count: 92 Current count: 93 Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
Fri Sep 13 04:00:03 CEST 2013 Reallocated sector count has increased in the last day. Disk 2: Previous count: 91 Current count: 92 Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
Mon Sep 9 04:00:03 CEST 2013 Reallocated sector count has increased in the last day. Disk 2: Previous count: 90 Current count: 91 Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
Fri Sep 6 04:00:03 CEST 2013 Reallocated sector count has increased in the last day. Disk 2: Previous count: 89 Current count: 90 Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
Thu Sep 5 04:00:02 CEST 2013 Reallocated sector count has increased in the last day. Disk 2: Previous count: 88 Current count: 89 Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
- StephenBGuru - Experienced UserIt is likely real, and you should replace the disk. You can check it on a PC using vendor diags if you wish.
Note that the reallocated sector count is tracked by the drive itself, the NAS is just reporting what the drive is telling it. - mdgm-ntgrNETGEAR Employee RetiredThe NAS reads the count and sends an email out if it has increased at 4am each day.
