stodge
Nov 02, 2011Aspirant
Recommend a second drive for a ReadyNAS Duo
I need to get a second drive for my ReadyNAS Duo (I thought it was a 2xxx but it says Duo on the case). I currently have a 500Gb drive (ST3500321CS) but I'm thinking of getting a 1-2Tb drive, so I can...
mdgm-ntgr
Nov 02, 2011NETGEAR Employee Retired
If you use a drive outside the list you will be denied support. I would stick to the drives on the list.
I've had a good experience with SeaGate but YMMV.
- Apr 03, 2016Retired_Member
