chasg
Jul 31, 2012Aspirant
recommendation for home + home office, confused by options
Hi All, I confess to being quite confused by all of the various ReadyNAS units, and I'd like to ask for some help making an informed choice. I work at home, and have networked my office machines...
chasg
Aug 01, 2012Aspirant
Actually, it was the firmware in the drives that I might have to update (according to the compatibility chart to which you pointed me).
Thanks for the manual! I much prefer to read a digital version.
Cheers!
Chas
Cheers!
Chas
spinaltap wrote: Don't be concerned with 'flashing' the firmware on the ReadyNAS. When your ReadyNAS arrives it is near plug and play.
Mine automatically updated the Radiator 5.35 software for itself. It will become apparent how to install add-on's one you're in 'FrontRow' (the ReadyNAS interface on your browser).
If you want some bedtime reading meanwhile, you can download the hardware and software manual for the NV+.v2 - http://kb.netgear.com/app/answers/detail/a_id/20683/~/readynas-documentation
