chasg
Jul 31, 2012Aspirant
recommendation for home + home office, confused by options
Hi All, I confess to being quite confused by all of the various ReadyNAS units, and I'd like to ask for some help making an informed choice. I work at home, and have networked my office machines...
chasg
Aug 04, 2012Aspirant
I didn't know about VirtualBox. I have an old copy of Windows around here somewhere (bought for an early copy of VirtualPC), I might try to see if I can get windows running that way (or via bootcamp).
I already have a SATA dock (very similar to the icybox you pointed me to). Very useful peripheral, looks like it's going to come in handy once again :-)
The WD Red drives would be an easy way out, but there would be a financial penalty (they're more expensive, and I'd have to deal with shipping the Seagates back). If "all" it takes is for me to somehow deal with a firmware upgrade, then I'll consider that time well spent.
Thanks again!
Chas
Thanks again!
Chas
spinaltap wrote: You could download the freely available VirtualBox - https://www.virtualbox.org - and acquire an OEM copy of the Windows OS to run on top of that.
You might also consider buying a SATA dock to test your new drive in, such as this - http://www.amazon.co.uk/Icybox-IB-111St ... 575&sr=8-3
Having said that, hindsight is a wonderful thing, as the other option is to return the Seagate drives for WD Red (that don't have the same firmware issue).
