JS310's avatar
JS310
Reconfig ReadyNAS 2100 post Factory Default
I am attempting to repurpose my NAS here at home.  When I Factory Reset it I am not able to get to the Admin Setup Wizard.  I use the new IP address that it obtained and use the default username and password but it logs into the My Shares page with no options.  I ran the RAIDar utility but the NAS is not being discovered.  Ideas?
  • JS310 wrote:
    ...and now the same password works.  What the heck?
    Was the RAID resync still running?  The web UI can become non-responsive when that is going on.
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    JS310
    Using RAIDar you should be able to run the setup. Have you tried accessing it via NAS_IP/admin? or have you finished the setup already?
    HTH
    • StephenB's avatar
      You do need explicitly browse to https://nas-ip-address/admin
      It won't redirect to the admin page if you just browse to https://nas-ip-address
      The username must be admin; the password for OS 4.2.x is netgear1.
      • JS310's avatar
        JS310
        Yup.  I did try that as suggested and it does not work either.  Is there a way to reinstall the OS...besides the boot OS Reinstall?  That did not seem to work either.  Now I cannot ping the device or access the Shares page.
ProSupport for Business
