bospe
Oct 08, 2016Aspirant
recover data
Hi
I have trouble to get my data out of the raeadynas 102. I can´t open the Raidar or the folder via browser. The disc might be bad..
But I wanna try to boot in the volume read only mode, but the manuel does not tell how to boot in volume read only mode, it just say yo can.
There are 2 disc in the nas.
Anyone here who can help how to get my files back?
Thanks Bo
1 Reply
The boot menu is in the hardware manual, you likely are looking in the software manual.
Pages 15-16 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/RN%20OS%206%20Desktop%20HW%20UM_15Oct2013.pdf
Try powering down the NAS, and removing disk 1. Then power it up and see if it boots normally. If that fails, try powering down again. Reinsert disk 1, and remove disk 2. Power it up, and see if it bots normally.
You can also test both disks in a windows PC (either connecting them to a Sata or eSata port, or using a USB->Sata adapter). Use seatools for seagate disks, lifeguard for western digital disks.
