Magmo
Mar 03, 2014Aspirant
replace with different hard drive
Hi One of my disks have failed and need to be replaced, I can replace with a compatible hard drive with equal or greater disk capacity without any issues right?
vandermerwe
Mar 03, 2014Master
Yes you can, although if you want the extra space to be added to the volume you'll need at least one additional disk with the higher capacity.
I'm assuming you are using xraid?
