Magmo
Mar 03, 2014Aspirant
replace with different hard drive
Hi One of my disks have failed and need to be replaced, I can replace with a compatible hard drive with equal or greater disk capacity without any issues right?
vandermerwe
Mar 03, 2014Master
Yes.
Do consider that you may need to adjust the idle timer using this tool from wd:
http://support.wd.com/product/download. ... 01&lang=en
Also consider that the seagate NAS drives are good, don't require this adjustment, and are slightly cheaper ( at least where I live)
