Magmo
Mar 03, 2014Aspirant
replace with different hard drive
Hi One of my disks have failed and need to be replaced, I can replace with a compatible hard drive with equal or greater disk capacity without any issues right?
Magmo
Ok, thanks. My first concern in this post was that one drive needed to be replaced, at least I thought so.. I got that message after I did a factory reset. But when I look now it says all my drives are ok!?
And also, I don't have the frontview gui in english, could you tell me what row number the "load cycle" is on?
