Magmo
Mar 03, 2014Aspirant
replace with different hard drive
Hi One of my disks have failed and need to be replaced, I can replace with a compatible hard drive with equal or greater disk capacity without any issues right?
vandermerwe
Mar 04, 2014Master
Did you use the hitachi drive fitness test tool?
http://www.hgst.com/support/downloads
You'll need to remove the drive withe Nas off and connect it to a PC.
