fmarchitects
Jan 09, 2012Aspirant
Replacement NV+ chassis
My NV+ went up in smoke yesterday and I'm expecting a replacement chassis from the nice people at Netgear. The RMA is showing the model as RND4000-300WWB. Is this a Readyas NV+ v1 or V2? and which Raidiator version would be the best to install? I use the Nas as a file server in a small office.
Thanks in advance.
Thanks in advance.
- fmarchitectsAspirantThanks mdgm,
I'm pretty sure I followed your migration info - I used a spare disk to upgrade the firmware, then migrated the disks, then recalibrated the fan. Frontview reported a resync of the disks and everything seems ok. I'm not sure how you check the firmware match between flash and disk?
I've migrated to User mode as per the link - does that mean setting up individual users/password logons for each machine?
Thanks - mdgm-ntgrNETGEAR Employee RetiredYou can use the same users for all users on all machines or different users. The choice is up to you to determine what suits your requirements.
The OS/firmware re-install instructions are here: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu - fmarchitectsAspirantOk. So I've got my replacement chassis, updated its firmware to 4.1.8, migrated the disks from my old chassis and now I've changed the security mode to User from Share as per SPHARDY's pdf. I've created some new shares and am copying the original shares to the new shares in line with his advice and will delete the original shares when this is complete. I'm hoping that this will resolve my access problems, which are as follows (bear with me please):
I try to connect under windows 7 network and see the Readnas Hostname. When I click this it asks, sometimes I get access to all the shares without any dialog, but sometimes up pops the dreaded 'Enter Network Password' dialog. Entering the user details and password to match Frontview, brings up 'Logon failure: unknown user name or bad password'. If I restart, it's pot luck whether I can connect.
I think this has all come about by upgrading to 4.1.8 and it's driving me crazy. Does anyone know whether the issue is caused by the fact that the original shares created under 'Share' Security Mode are still there or is it a Windows 7 issue?
Thanks - mdgm-ntgrNETGEAR Employee RetiredYou need to reset permissions on the shares.
Is your Windows username or computer name the same as any of the share names?
