stodge
Mar 19, 2012Aspirant
Replacement screws - available in store?
I've read a few topics on this and I don't have the original packaging, nor are there any spare screws tapes inside the spare tray. I tried some flat headed screws but they're not low profile enough. Are these screws available anywhere in any stores? This is driving me nuts as I can't install the drive and my files aren't duplicated. Thanks
- mdgm-ntgrNETGEAR Employee RetiredGIve NetGear tech support (http://www.readynas.com/support) a call.
- Flash1AspirantIn the meantime you can "borrow" some screws from the chassis or install the drives with only 2 screws in each tray diagonally from each other.
- stodgeAspirantI managed to get some from my trusty Linux says admin guy at work! :)
