anubis1
Jun 11, 2012Aspirant
Replacement Tray Screws
Hi, I have misplaced the remaining tray screws for my Pro and I was wondering if someone could tell me if these screws are ok to use. They look the same as the others I have and from what I can t...
PapaBear1
Jun 11, 2012Apprentice
They may.
For a temporary situation, you can rob two of the screws from the trays that you already have in service. This hint came from the ReadyNAS development team who only use two screws per tray (diagonal pattern with only one per side). If you have three trays in service, this will solve your situation while seeking a permanent solution or waiting for some to arrive in the mail.
