dgrb
Aug 13, 2013Aspirant
Replcing failed diisk
I've had my readynas nv+ (sparc) for about six years now. Couple of years ago replaced the original 500GB drives with Seagate 2TB. Although they seem to be the same make/model as those causing http...
Aug 14, 2013Guru - Experienced User
Yes.
Note I revised my previous answer - I edited too much of your second question. 6 GB/s SATA specs are fine - my "No" was in response to "is this likely to be a problem?"
