srvteam
Jul 06, 2017Aspirant
Replication License for ReadyNAS 2100v2
I have two of these that I'd like to use with replication but can't find any way to get the license for either. The device specifics are as follows:
ReadyNAS 2100 v2
Serial: 2KU427R800545
Firmware: RAIDiator 4.2.31
Memory: 1024 MB [DDR2]
ReadyNAS 2100 v2
Serial: 2KU427R2004EE
Any assistance you can provide will be much appreciated. Also - the first device listed above is being replaced under warranty (chassis only) and should have arrived by now. I have not seen it - could I get an update from anyone here?
Thanks!
1 Reply
If you google on RN00RPL1 you'll find a couple of sources.
They are pretty expensive - another alternative is to switch the 2100s to OS 6 (which is free). That will work on the v2, but not the v1. Netgear doesn't support this, but of course the hardware warranty still applies.
