Totor8602
Jun 01, 2024Follower
Request help Malfunction Netgear ReadyNAS 214
Hi. I have a Netgear ReadyNAS 214, bought in 2017. This one doesn't work anymore. When I start it, it boots up to 98% and then nothing happens. Can I buy a new Netgear ReadyNAS and use the disks with data from the old one,or will there be issues ?
You might get better help posting in the readynas forums versus the netgear Armor forums.
The disks can be migrated to several other ReadyNAS... BUT the problem is likely on the disks.
Do you have a backup of the data?
Have you ever used the linux command line interface?
