BotanyBay
Sep 15, 2017Tutor
RN 626 and ST10000vnb004 differences with st10000vn0004
I just received an ST10000vnb004 vs ST10000vn0004 which I had ordered. Does anyone know if there are any differences which would make this drive "unsupported"
BotanyBay
Sep 18, 2017Tutor
I called Seagate this morning and discussed the question with a knowledgeable support person. I asked them to summarize our conversation in an e-mail so I could provide feedback to the group with regard to these drives. I received the following:
"Thank you for contacting Seagate Support. As discussed the model number ST10000VN0004 and ST10000VNB004 are Inronwolf 7200, SATA units with a sector size of 512E. I hope that this information is helpful for you. "
Based upon the verbal discussion these are just a different run number of the drive.
Looking online over the weekend and using the UPC code I found that it may be a case of the Model number and MPN number being different.
Attribute Value
| UPC | 763649117972 |
| EAN | 0763649089248 |
| MPN | ST10000VNB004 |
| Brand | Seagate |
| Color | 10TB |
| Model | ST10000VN0004 |
| Binding | Personal Computers |
| Publisher | Seagate |
| Part Number | ST10000VNB004 |
| Manufacturer | Seagate |
i.e. the Model Number is ST10000VN0004 but the MPN is ST10000VNB004, The ST10000VNB004 number is printed on the outside of the box of the drive (i.e. Seagate's packaging - Without the Ironwolf printed label). I have verified the serial number as a fully waranty part. I suspect that the number printed on the drive itself may be the Model Number instead of the MPN value.
I will update after I get the box open.
BotanyBay
Oct 08, 2017Tutor
Success! The drive in the box was in fact a model ST10000VN0004 , even though the outside of the box had ST100000VNB004.
