nobrainer
Feb 28, 2014Tutor
RN NV+ v2 & WD Red 4TB
I checked the HCL and found the WD Red 4TB WD40EFRX was listed as acceptable. But elsewhere in the forums it mentioned searching for that specific model. I couldn't find any posts on the nv+ v2 (fw:...
Mar 01, 2014Guru - Experienced User
I've had good luck with the WD30EFRX (though mine were shipped before WDC shortened the head-parking timer, so I didn't need to use their tool).
Generally I do run diags on a PC before installing, and check for firmware updates as part of that process.
