Hawk321
Nov 04, 2021Apprentice
RN104 - 18 TB HDDs
Hi, because I couldnt find any information upfront I tested now 2 different 18 TB HDDs in the ReadyNas RN104 by myself. - Toshiba MG09 18 TB - (MAMR) - 32.000 kbytes/s avg. write speed - 30.00...
Hawk321
I corrected it, forgot to add some 0 :-)
After a while it even drops down to 17.000 kbytes/s with load on the other discs. Not fast at all and maybe the reason for the "stale points" I get while Chia farming.
Should be much faster:
Its only 10% of the speed which it can go.
Nov 04, 2021Guru - Experienced User
FWIW, 32.000 kbytes/s is just 32 kbyte/s in English speaking countries. Using mbytes/s would be less open to misinterpretation.
It's been a while since I tested speed on the RN100 family. But my recollection is that it can deliver about 70 mbytes/s read and 50 mbytes/s write.
- Hawk321Nov 04, 2021Apprentice
Its the NAS itself the network speed is nearly 1 Gbit/s . Check the pic attached.
I copied a test file with 3 GB from a SSD to an NVME/2 drive on another PC in the network.
