mar2251
Apr 17, 2017Aspirant
RN104 - Maximum Capacity
Hi,
I have an RN104 running the latest software.
Would there be a problem and an inability to give it 4 x 6Tb Hard Drives? Or even 8Tb Drives.
I want to increase the back up capacit...
- Apr 17, 2017
Part of the point of mentioning 10TB disks is that if you do get 6TB/8TB disks there is still some potential there for future volume expansion.
mar2251
Hi,
I really don’t want to get 10Tbs only 6 or 8’s are these equally usable and compatible?
Albert
Apr 17, 2017Guru - Experienced User
Third try: Yes, with the considerations noted above.
The hard drive compatibility list is here: https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List
Both the WD60EFRX and the WD80EFZX work well. If you go with Seagate, the best options are the Ironwolf ST6000VN and ST8000VN models (digits after the VN don't matter). With the Seagates you will have to remove the tooless plastic inserts in the drive tray.
- mdgm-ntgrApr 17, 2017NETGEAR Employee Retired
- capazApr 18, 2017Tutor
StephenB wrote:The hard drive compatibility list is here: https://community.netgear.com/t5/forums/replypage/board-id/readynas-general/message-id/13695
I think you may have grabbed the wrong URL. :-)
I did find the compat. list here, though: https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List
- StephenBApr 20, 2017Guru - Experienced User
Looks like a cut/paste error on my part. I've edited my original post, just in case someone else clicks there.
I'm glad you found it on your own.
- Sep 02, 2016Retired_Member
