mar2251
Apr 17, 2017Aspirant
RN104 - Maximum Capacity
Hi,
I have an RN104 running the latest software.
Would there be a problem and an inability to give it 4 x 6Tb Hard Drives? Or even 8Tb Drives.
I want to increase the back up capacit...
- Apr 17, 2017
Part of the point of mentioning 10TB disks is that if you do get 6TB/8TB disks there is still some potential there for future volume expansion.
mar2251
Great thanks for you help. Trying to get the answer from Netgear is like pulling teeth.
Can the Nass memory be upgraded?
Apr 17, 2017Guru - Experienced User
mar2251 wrote:
Can the Nas memory be upgraded?
No, it's soldered into the system board.
The forum is often faster. Note that some of the folks here are from Netgear (including mdgm-ntgr)
- Sep 02, 2016Retired_Member
