Calder
Feb 27, 2017Guide
RN104 100% CPU within 1 month of restarting
This started 2 updates ago (6.6.0). Within 1 month or a fresh restart, both of my RN104 will suddenly reach 100% usage within a few minutes of each other. This has been happening for a few times now and I am wondering if anyone is experiencing this.
- Retired_Member
Yes, experienced that too with AntiVirus service enabled. See whether it gets back to normal after you disabled AV.
I can confirm that disabling the AV service resolved this issue for me and my 104.
Symptoms were timemachine unable to find timemachine backup volume, admin website did not load or reconnected or reloaded all the time, out of disk space messages. All this went away after disabling the AV service.
- Retired_Member
Great to hear that. Let me recommend to keep it disabled until the new firmware 6.7 will be available. You could also try to toggle it on again and see whether it decides to behave now. At least you have a workaround.
- CalderGuide
Thanks for the tip. Unfortunately I don't use AV or time machine or any "fancy" features. Mine are both just a iSCSI setup with a SMB share for image storage. I have checked that I don't have anything scheduled for the volume like blanace, defrag, etc.
Maybe next update will fix this issue and my other issue with UPS not being detected after a restart.
Cheers!
- CalderGuide
Yup, as predicted, it happened again 23 days after last restart. Both RN104 went to 100% CPU and stuck there. I guess I am on a 3 week restart cycle with these two NAS.
