gdlgiii's avatar
gdlgiii
Tutor
Feb 22, 2016
RN104 2 volumes mix drives
I have two volumes named VOL1 and VOL2. Each volume is a RAID1 mirror set with 2 Toshiba 1TB disks in each volume. I would like to increase VOL2 from 1TB to 3TB by replacing them with 2 WD RED 3TB dr...
  • StephenB's avatar
    Feb 23, 2016
    gdlgiii wrote:
    Are having 2 different brand drives on separate volumes a supported configuration?
    Yes.  In fact you can mix brands in the same volume, and (with xraid) can have different disk sizes in the same volume.
ProSupport for Business
