ecybertom
Mar 21, 2017Aspirant
RN104 lock up and resync
System has 4 drives installed, two 6 and two 8 TB drives. I was deleating from windows two large back-up files (Acronis) to get more room. Part way through the process the NAS locked up. To power down I had to unplug the power supply. When it booted back up, it came up to this screen in system / volumes. The error code is the other photo being uploaded. The resync continues but not much confidence in the outcome. Help
- mdgm-ntgrNETGEAR Employee Retired
Do you have a backup?
Can you send in your logs (see the Sending Logs link in my sig)?- mdgm-ntgrNETGEAR Employee Retired
Can you access your data if you boot into volume read-only mode?
- ecybertomAspirant
I have not tried that. I was waiting for the resync to finish. Question, is their a problem with the 104 platform. I know it is the bottom of the line processor and memory wise. This is the second major problem I have had with this box. I also have a 214 that seems to ignore the same type of operation.
