pdasterly
Dec 07, 2014Guide
RN104 support 6tb drive
I have a rn104 with 2 2tb drives. Can I add 2 more 6tb drives(red nas)? Using JBOD
vandermerwe
Dec 07, 2014Master
6 tb drives are not on the hard disk compatibility list for the 104 so Netgear will deny support if you develop a problem.
There is every indication that they would work though.
Note that the 104 has a volume size limitation of 16 tb. This would not affect you as you are using jbod, however you would probably just reach 16 tb if using Xraid or raid 5.
You have the data on you jbod volumes backed up somewhere I hope.
Why firmware are you running?
