GDM52's avatar
GDM52
RN104 Upgrade to 6.10.1 breaks Apache2
Hi,
I have just upgraded firmware from 6.9.5 to 6.10.1 but apache2 is not starting properly, so am unable to access my web server.
Frontview (Admin Console)is working OK.
Aug 06 17:00:42 readynas fvapps[8029]: WARNING: Excluding bad https config for a
pp 'phpmyadminr6'
Aug 06 17:00:43 readynas fvapps[8029]: WARNING: Excluding bad https config for a
pp 'phpr6'
Aug 06 17:00:47 readynas apachectl[8171]: apache2: Syntax error on line 200 of /etc/apache2/apache2.conf: Syntax error on line 1 of /etc/apache2/mods-enabled/wsgi.load: Cannot load /usr/lib/apache2/modules/mod_wsgi.so into server: /usr/lib/
apache2/modules/mod_wsgi.so: undefined symbol: ap_accept_lock_mech
Aug 06 17:00:47 readynas apachectl[8171]: Action 'start' failed.
Aug 06 17:00:47 readynas apachectl[8171]: The Apache error log may have more inf
ormation.
Aug 06 17:00:47 readynas systemd[1]: apache2.service: Control process ex
ited, code=exited status=1
Suspect it's the mod_wsgi.so at fault, but have no idea how to fix it.
Any help appreciated.
Thanks
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    GDM52
    Have you tried doing OS-Reinstall? This have resolved a previous post regardng Apache2 not running after the update.
    HTH
    Regards
    • GDM52's avatar
      GDM52
      Hi,
      Tried OS reinstall - thats's made things worse.
      Now I can't access Admin page .... any ideas???
      Cheers
      • GDM52's avatar
        GDM52
        Realises that OS install changed IP address (DNS not updated yet)
        Now have access to Admin page and SSH
        Still no apache though
        Cheers
    • Marc_V's avatar
      Marc_V
      GDM52
      What does RAIDar show? Can you download the logs through RAIDar?
      Regards
      • GDM52's avatar
        GDM52
        Sorry - Don't use RAIDar
        Any alternatives???
ProSupport for Business
