igl00
Jul 09, 2015Aspirant
RN10400 won't power on/dead
Hi,
After about 2 months of use, yesterday I found that my ReadyNas was powered off and I wasn't able to turn it on again. I believe it is the power supply as its led doesn't light up. I've tried with another mains power cable with no luck and also I've tested the DC pins and no current is coming from them. Before I contact support and ask for a power supply replacement, is there something else I could try?
I find it pretty strange because there isn't a reason for this, when it has happened I was at home and AFAIK there haven't been any surges or blackouts or anything power related.
Thanks!,
Igl00
Thanks!,
Igl00
- StephenBGuru - Experienced UserI can't think of anything else to try, and you've clearly isolated it to the supply already.
So I'd just call support. - igl00Aspirant
StephenB wrote: I can't think of anything else to try, and you've clearly isolated it to the supply already.
Thanks!
