Zansett
Feb 18, 2019Aspirant
RN202 Readycloud desktop app don´t connect outside home network
Hello !
When i am outside my home network, the readycloud desktop app for windows, shows my NAS, as "Offline"
If i sign in to the webpage (readycloud.netgear.com) (From a remote location), i will find my Nas and everthing looks fine.
I can upload, and download files without any problems.
At the remote location, i have tried different routers, Nighthawk R1800, Nighthawk M1 mobile router, and a standard Android phone as a hotspot, nothing works.
I also tried the Android version of Readycloud, but it says "Invalid credentials or service is unavalible"
All theories are welcome :)
- Marc_VNETGEAR Employee Retired
Hi Zansett
Welcome to the Community!
Have you checked your NIC settings on the NAS? Adding a DNS server like google and your router gateway address. Mine is working fine (Android, Portal, Desktop App). I was trying to check if there's any outage but its working fine on my end.
Try logging in and out of ReadyCloud and check if you can disable any security software installed on your PC.
Hope this helps!
Regards
- ZansettAspirant
Hi
I have tried everything i can think of.
The NIC is configured to use DHCP, and dynamic IP.
Do i need to make this static, and do some portforwarding in the router, to make this work ?
In this case i also need the portnumbers to forward.
Since i can access it via the webportal, from anywhare, i assumed the settings was ok.
On the computer i only have windows built in firewall, i have tried to disable it, no success.
I also tried signing in and out from Readycloud-app, no success
I have tested with two differnt computers, one running windows 8.1, and the other running windows 10, no differens.
I also tried connecting the computer directly to the fiberconverter, without any router between, no success.
Also the Android app, can´t access it from a remote location, not via wifi or 4G
Everithing is working fine when i am on the same network as the NAS.
But on a different network i can only access the NAS from the webportalAny ideas
Niklas- Marc_VNETGEAR Employee Retired
Hi Zansett
Can you try reinstalling the App using this link
Windows: http://readycloud.netgear.com/client/install/ReadyCloudSetup.exe
MacOS: http://readycloud.netgear.com/client/install/ReadyCLOUD.pkg
Hope this helps!
Regards
