zyphaz's avatar
zyphaz
RN204 6TB hot-add expansion resync: ~90 DAYS?
I added a 4th 6TB HDD to what was intially a 3x6TB setup in my RN204.  I expected the rebuild to run into the weekend with a hot-add of that size... but checking the estimated resync time ~19 hours later shows that it has not even crossed the 1% threshold and the estimated remaining time is 90.4 days out.
This is a backup NAS (bulk storage/rsync target) for another mfgr's 8 bay so it wouldn't be out of the question to rebuild the array as a fresh new 4 disk array... but something else has to be going on here, right?
FWIW, the logs in the GUI are clean... with no errors related to the disk add.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Which firmware are you running?
    Which services are you running?
    Which apps are you running?
    Welcome to the Community!
    • zyphaz's avatar
      zyphaz
      Thanks for the welcome.
      6.4.2
      System > Settings > Services is empty.
      Apps > Installeld Apps is empty.
      • StephenB's avatar
        Surely you jest.  Did you click on it to expand it?  It should something look like this:
        If the antivirus service is enabled, then disable it.
ProSupport for Business
