PRASHANT1971
Mar 26, 2022Follower
RN212 READYCLOUD NOT WORKING ON WINDOWS7
RN212 NAS READY CLOUD DESKTOP APP NOT CONNECTING IN WINDOWS7 GIVING NETWORK ERROR BUT ITS WORKING IN WINDOWS 10. SO IS WINDOWS7 WILL NOT SUPPORTED FROM NOW ON OR WHAT .. FACING PROBLEM SINCE...
scravatt
Mar 27, 2022Apprentice
I have the same issue here. Was working fine and then won't connect a few days ago. Windows 10 works fine but Windows 7 just stopped working. I see 2 errors: "ReadyCLOUD Server Unavailable" when I try to log in. On the setting page, If I click on check for update, I get the error "Failed to connect to ReadyCLOUD server". It seems like it can't find the server to connect. Nothing changed on my end.
Sandshark
Mar 27, 2022Sensei
Are you running any kind of firewall or similar software that may have updated and is now blocking that traffic?
