Kardano
Apr 03, 2017Luminary
RN214 - No PHP and PHP apps on FW 6.7.0
After update FW to 6.7.0 (from 6.6.1) no PHP apps works. And no Web interface.
I Tried Reinstall OS - not hepling.
I Tried Factory default. (Twice) and config NAS.
Web interface is OK. after i...
- Jun 22, 2017
I installed the final firmware release and the problem seems to be solved.
Thank you!
an_user
Jun 06, 2017Aspirant
Is there still a solution?
I can't get php running on my RN214 OS6.7.4 (other apps: resilio sync and svn)
In browser I can see only the php code too.
