Kardano
Apr 03, 2017Luminary
RN214 - No PHP and PHP apps on FW 6.7.0
After update FW to 6.7.0 (from 6.6.1) no PHP apps works. And no Web interface.
I Tried Reinstall OS - not hepling.
I Tried Factory default. (Twice) and config NAS.
Web interface is OK. after i...
- Jun 22, 2017
I installed the final firmware release and the problem seems to be solved.
Thank you!
Kardano
Jun 09, 2017Luminary
It will be fixed for me AFTER release final FW 6.7.5 and php will be working. NOT SOONER.
Heino
Jun 09, 2017Guide
I agree that we should not close this thread until a working final release of FW 6.7.5 has been published.
But marking an answer as accepted is still a good idea. Imagine someone else is having the same problem and hopefully finds this thread. Then he knows that there is a solution and he can jump immediately to the accepted answer without needing to read through all the posts.
