MacSI's avatar
MacSI
RN312 disk compatibility
Hello
I want to upgrade storage in my RN312. Witch hard drive can I use ?
Can I use WD60EFRX ?
Thx
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Yes you can use that model. There are many options on the hard disk compatibility list.
    • ctechs's avatar
      ctechs
      Apprentice
      The hard disk compatibility list is not showing up here. There's just a blank spot on the page where it should appear. Tested in both Firefox and Chrome. Edge has this message:
      This content can’t be shown in a frame
      There is supposed to be some content here, but the publisher doesn’t allow it to be displayed in a frame. This is to help protect the security of any information you might enter into this site.
ProSupport for Business
