Wenzu1981's avatar
Wenzu1981
RN31400 – ReadyNAS 300 Series - Volume Data RAID Level 5 Innactive
Hi
I have a Netgear Ready NAS 314.
I recently have experienced an issue with my Ready NAS. Firstly I was not getting an IP address and had to do an OS Reboot to try and re-establish a connection. I finally was able to access the Admin page after getting the IP Address fixed. I was prompted to update my firmware on the Admin page. I usually don’t enter the admin page so had not been exposed to this firmware update before, so have therefore accepted the update.
Following the firmware update to 6.10.7, I have basically no access to the volume data on my ready NAS. The status shows Volume data RAID 5, inactive disks 1,2 ,3 ,4 and states that 10.9 TB (100%) of 10.9 TB is used. I was aware that prior to the firmware update, I had 19% storage availability free. I should add that I use 4 x 4TB Hard drives on my device.
I have gone through the Netgear Community support forums and have since learned that my Ready NAS 314 may not be compatible to the new firmware 6.10.7. I have downloaded an earlier version of the firmware however it wont accept earlier versions. Currently doing a Disk Test which is in progress.
Can anyone suggest a solution or provide any advise to retrieve my data / fix my ready NAS.
Any assistance would be greatly appreciated.
Regards
  • Hi All.
    In addition I have also logged a case with the Netgear support team (Case Number - 46064517). My product is no longer supported by Netgear, and was directed to the community support forums. It has been 4 days, and I keep emailing Netgear support, however have not been getting a response, which is very disheartening.
  • StephenB's avatar
    That is not the case.
     Do you know what firmware you were running before?
    There are multiple causes for the inactive data volume, so I normally do recommend using paid support for this.  FWIW, it isn't caused by a firmware update.  It's likely there was an issue already there (but not reported), and the update just exposed it.
    If you haven't downloaded the full log zip from the admin ui, I suggest you do that now.
    You should have been able to purchase a support contract.  That wouldn't cover failed hardware, but it should include software support that would likely let you remount the volume.  There is also the option of getting a data recovery contract.  I'm tagging the mods, as they might be able to check on this for you - Marc_V and JeraldM
    It should accept any 6.10.x version.  But this won't help, and I don't recommend downgrading firmware right now.
    • Wenzu1981's avatar
      Wenzu1981
      Thanks
      I have downloaded the logs, however I don't know what to do with them.
      Prior to losing my IP address I tried to send a file accross to the NAS, and it stated it was write protected. I rebooted the unit and then the issues became apparent. It looks like the issues may have been there fore the software upgrade.
      I am also happy to put in a support contract, however everywhere I go it states that I am out of warranty and am not sure where to go to obtain a support contract. Can you please send a link?
        Wenzu1981
        Would remounting the volume result in data loss? If not what is the process of doing this?
        Would prefer to obtain paid support contract, and it would be great if you could advise how to do this. If 1 Hard Drive has failed I could easily replace, but my preference would be to retrieve the data. which would be about 8TB in data. Mainly video files.
ProSupport for Business
