TangoWhiskey123
Jun 21, 2019Aspirant
RN316 updated Firmware to 6.9.3 and now have no volumes
I did the firmware upgrade to 6.10.1 and everything seemed to be going well unitl the unit needed to restart. Then it wouldn't. The blue power light just blinked. RAIDar says the unit is starting, but I left it for 24 hours and it never got past the starting step. RAIDar shows both drives with the green checkmarks. If I remove the drives, the chasis boots OK and shows as healthy. If I put in the drives in after it has booted, it does not recognize them as having volumes ready to mount. How can I get back to my having a booting unit with the data on my drives?
When I boot just the chasis, the logs show monting other than a few message from the latest boot.
Thanks
You should consider using paid Netgear support (my.netgear.com) for this.
BTW If you purchased your NAS (new) between 1 June 2014 and 31 May 2016 you have free lifetime chat support.
- TangoWhiskey123Aspirant
How do I find out about the free support? I bought it new Dec 2015 and free support would be nice.
You should be able to get it via my.netgear.com.
