floslight
Jan 17, 2014Aspirant
RN316: Volume is degraded
Hello Everyone, Noticed that since this morning I have a yellow alert in my log: Fri Jan 17 2014 10:11:23 Volume: Volume 'data' health changed from 'REDUNDANT' to 'DEGRADED'. Somehow, there i...
Jan 17, 2014Guru - Experienced User
Updating your backup is the first order of business.
It is probably best to contact support on the array.
I guess you could try removing/reinserting the drive with the NAS running and see if it gets re-added/rebuilt. Or take the opportunity to upgrade to 6.1.6 beta, and do the factory reset.
EDIT: You should probably also download the logs and look at the SMART stats for the drive. Maybe also run lifeguard on an PC to check it.
