arun-india
Oct 06, 2025Aspirant
RN426E22 NAS Stuck on "Welcome to Netgear Storage" – No Button Response, No Network Access
Hi Team, My NAS (model: RN426E22) is stuck on the "Welcome to Netgear Storage" screen. There is no response when I press the center button or any of the four surrounding buttons. Additionally, the ...
- Oct 23, 2025
Replaced RAM & Working Fine
I removed the RAM stick and powered it on — it still stopped at the same “Welcome” screen. Then I replaced the RAM with another one, and this time it showed “Booting...”. After that, I inserted the disks and powered it on again, and now it’s working fine. Thank you very much for your inputs Sandshark & StephenB
I’m planning to collect all technical details to ensure I can rebuild the shares from a Linux PC if the NAS fails again in the future. Could you please advise what information I need to note and where to find it?Also, since this product is no longer supported, my company management is ready to procure another rack-mountable NAS. Could you experts please suggest a reliable, rock-solid make and model?
Sandshark
Oct 12, 2025Sensei
The reset button menu also relies on the flash content, just different content. So USB recovery is a good thing to try even if you can't get to that menu. ReadyNAS can be picky about what USB drives will work for a recovery, though OS6 units are less sensitive than older ones. So if it doesn't work, you should try with more than one (different brand) USB device before deciding it won't work. Using a USB drive with an access LED is helpful. If it accesses the drive briefly but nothing else, it usually means the drive itself is incompatible or you made a mistake in creating the recovery. If it's not accessed at all, it typically points to a hardware issue. USB recovery can be done with or without drives. Just make sure you are recovering to the same version you had before.
arun-india
Oct 13, 2025Aspirant
Hi Sandshark , A quick question , USB recovery means OS Re-installation right ?
