alaserguy's avatar
alaserguy
Follower
Sep 12, 2018
RN516 - HDDs with different models or different firmwares
So a while ago I started the process of upgrading all six 3TB drives from our RN516 to 6TB drives. I checked the compatibilty and ordered six of WD60EFRX. Once I recieved them (only recently), I started hotswapping the disks one-by-one, waiting for the drives to resync each time. There were never any errors so I assumed everything was going fine, but now I've noticed that one of the drives was actually recognized as a WD60PURX, which I found out is a model typically optimized for surveillance and should have the same hardware but different firmware. BUT, according to the admin page it actually has the same firmware as the normal WD60EFRX's (80.00A80). So I'm not sure if this is a problem. My other concern is that two of the other WD60EFRX's have their firmware listed as 01.00F.6, but are otherwise behaving normally.
So, I would greatly appreciate if someone could tell me if any of this is worth worrying about and if I should ask the company to replace these drives for me.
1 Reply
  • StephenB's avatar
    My own WD60EFRX are running 82.00A82 firmware.
    You can potentially update the firmware in a windows PC.  I would contact the seller on the WD60PURX, as you should get the product you purchased.
ProSupport for Business
