bigredbeast
Apr 11, 2017Aspirant
RN716 with 10TB Disks
Hi all, I have confused myself comparing the spec sheets and the HCL for the RN716x and need a bit of clarity if anyone can help? 1. Are 10TB disks supported in the RN716X ( I believe so as the H...
- Apr 11, 2017
1. Yes. Spec sheets reflect what was available when they were written.
2. Yes
3. Yes, but I'd recommend considering other RAID levels e.g. RAID-6, RAID-50 etc. In any case regardless of which RAID level you use be sure to backup your data. Don't store important data on just the one device.
4. Yes
mdgm-ntgr
Apr 11, 2017NETGEAR Employee Retired
2. Yes
4. Yes
bigredbeast
Awsome, many thanks.
