tlkohler
May 19, 2016Aspirant
RN716 - Management service is offline (OS6.4.2)
Good afternoon all
I attempted to access my ReadyNAS RN716x this morning (as I normally do everyday) and was greeted with the error message that my device was not available.
It is not accessible in ReadyCloud nor using Raidar 6.1. When I attempt to type the IP address into my browser (I've tried several, IE, Chrome, FireFox) it tells me the site cant be reached. When I use the Raidar app and select Admin Page I'm told the same thing. I have read the KB pages on this issue but none seem to EXACTLY match my issue other than the fact I can't access the NAS. Any pointers or assistance would be greatly appreciated and thanks in advance.
Your root partition is very full with a large MySQL database stored on the 4GB root volume.
I moved that over onto the data volume.
The LMS app is still using a few hundred MB of space.
- kohdeeAdministrator
Management services is offline means that your ReadyNAS's database is not currently turned on. There's a few reasons why that could happen (like a full OS caused by an app, or for some reason, the database isn't started).
Try this:
http://IP_of_readynas/dbbroker?start_svc=readynasd
- mdgm-ntgrNETGEAR Employee Retired
If that does not resolve it then download your logs using RAIDar and send those in (see the Sending Logs link in my sig).
- tlkohlerAspirant
When I attempt to download the logs thru RAIDar I receive the following: first a message box opens asking for login authentication. When I enter my username and password an error message box popps back indicating I did not enter a valid username or password.
I rebooted my 716 xNAS and watched the RAIDar app while it was booting up. The status indciation changed from System starting up to Managemnt Service is offline. At this point I can not get access to anything from the RAIDar app.
- tlkohlerAspirant
Thanks you for the suggestion. I attempted http://IP_of_my_readynas/dbbroker?start_svc=readynasd in several browsers and none will display a page. I get "This site can't be reached. xxx.xxx.x.xxx refused to connect"
- Jun 10, 2022Retired_Member
