tony359
Mar 02, 2014Apprentice
RND P6610
Hello all, I'm new here, I've just got from a friend an old ReadyNAS. The bottom label says "ReadyNas Pro RNC P6610". On the website it says the model has been replaced by the P6610-200 and I canno...
mdgm-ntgr
Mar 03, 2014NETGEAR Employee Retired
Well the newer models may have a newer motherboard. If your Pro has an older motherboard rev you may be more limited in what CPU you can use.
