doublem70
Dec 02, 2012Aspirant
RND4000 v3 HD replace
Hello i'm an Italian lucky owner of a RND4000 v3 ReadyNAS® NV+ with RAIDiator 4.1.10 firmware, equipped with no. 4 HD Western Digital WD20EARS-60MVWB0 2Tb Hard Disk. My system now is working perfect...
doublem70
mdgm wrote: You have a NV+ (v1). Any 2TB disk on the compatibility would be a suitable replacement. Yes 2TB drives are the max supported on your model.
Welcome to the forum!
Thanks for Your support...
Now i'm not worried anymore :)
Do You know if is there any system to improve the network performances?
Thanks again
Maurizio
