mclancer
Jun 17, 2016Aspirant
RND4000 with no power.
Hello I could use some help please. We were having a number of power outages. After realizing my ReadyNAS was not connected to my Cyberpower battery/surge protection box, I then made sure it was. ...
- Jun 22, 2016
The pinout link is here: http://www.readynas.com/download/archive/pdf/ReadyNAS_PSU_pinout.pdf
Jun 18, 2016Guru - Experienced User
To answer the second question first, you can look here: http://home.bott.ca/webserver/?p=306
The NV+ uses a standard ATX supply with a modified pinout (which you find here: http://www.readynas.com/download/archive/pdf/ReadyNAS_PSU_pinout.pdf).
blind1
Jun 18, 2016Aspirant
I'm in the same boat - eg no power to NAS
From previous posts people have said they have conatcted support and got a new PSU. Where have they gone on the website as I seem to go round in circles with no ability to raise a ticket or send an email.
- JennCJun 18, 2016NETGEAR Employee Retired
Hello blind1,
I believe NETGEAR already ran out of stock of this power supply since this model number joined EOL devices many years ago.
RND4PSU1-10000S is the part number of the power supply, you might want to try your luck on eBay, there are others out there who sell this.
- StephenBJun 19, 2016Guru - Experienced User
You can find them on Amazon also, but they are quite expensive - 3x the cost of an ordinary ATX supply.
An ordinary ATX supply likely won't fit into the case, but you could connect it externally (making the needed pinout change on an extender cable). That isn't a good long-term solution, but would let you get your data off the NAS.
