Sly_Raskal's avatar
Oct 31, 2016
Seagate 6TB Ironwolf (ST6000VN0041) Incompatible with ReadyNAS disk trays
I took a risk and purchased 4 x 6TB Seagate Ironwolf drives, Model #ST6000VN0041 and unfortunately the mounting holes for the disks are not matched with the trays that come with the ReadyNAS 314.
Now I need to decide if I wish to ...
  1. Sand down the 2nd pin and only mount the drives using one screw and hope that the drives don't have any issues with the ReadyNAS OS
  2. Return the drives and go with something else.
Pictures speak for themselves....
You can see by the lines I've drawn that the drives don't have the customary holes in the locations that most other drives do, and so they don't line up with the ReadyNAS tray:
In addition, the black tray holder has two pins that slot into the screw holes on the sides of the drive, one pin lines up, but the other has not corresponding screw hole in the drive to use:
Tray pins:
Missing hole in drive for 2nd pin on tray:
  • I went ahead and sanded down two of the pins on one disk tray and mounted a hard disk, went through system setup which included a system update to the latest firmware (6.6.0), and so far things appear to be running smooth.
    Going to attempt installing the remaining three drives to expand storage.
  • kohdee's avatar
    kohdee
    Administrator
    The plastic insert on tool-less trays comes out, so you didn't have to clip the plastic tray to fit the drive in, widthwise.
    • baeckerg's avatar
      baeckerg
      doesn't that defeat the purpose of "toolless"? And it is not easy to remove the frame.
      • mdgm-ntgr's avatar
        mdgm-ntgr
        NETGEAR Employee Retired
        Well it is a workaround so that you can use these disks with the tray and the screws you already have.
ProSupport for Business
