ramjet73
Jun 12, 2015Aspirant
Seagate ST3000DM001 7200.14 Compatibility and Warranty
I recently had some corruption problems with my ReadyNAS Ultra 4 and with the help of Netgear technical support it is back up and running in a somewhat patched mode. Their recommendation is to upgrad...
vandermerwe
Jun 14, 2015Master
Well, that would not make very good business sense from the drive manufacturer's point of view. Essentially you are saying they should insure you against making the wrong choice in the first place. Even if they offered this, the net cost to the consumer would likely be higher than if they had just bought the most appropriate drives at the outset.
Can you not return the DM drives?
