ramjet73
Jun 12, 2015Aspirant
Seagate ST3000DM001 7200.14 Compatibility and Warranty
I recently had some corruption problems with my ReadyNAS Ultra 4 and with the help of Netgear technical support it is back up and running in a somewhat patched mode. Their recommendation is to upgrad...
Jun 14, 2015Guru - Experienced User
Well, if I had an option to upgrade the drive when doing an RMA, I'd certainly look at the deal. i think it would build some customer loyalty even if I decided not to take it.
vandermerwe wrote: Well, that would not make very good business sense from the drive manufacturer's point of view. Essentially you are saying they should insure you against making the wrong choice in the first place. Even if they offered this, the net cost to the consumer would likely be higher than if they had just bought the most appropriate drives at the outset.
I don't see any business issue for the vendor, since it is limited to a failed drive replacement under warranty and they are setting the upgrade price.
From what I've read here and elsewhere, I'd personally avoid DM for NAS use. If I were to go with Seagate I'd pick a VN drive.
ramjet73 wrote: I don't think so since the first two were purchased from Newegg in early May of this year. I still think they may be the "right" drives for me given my situation and the fact that they are on both Seagate's and Netgear's certification lists for NAS drives but time will tell.
vandermerwe wrote: ...Can you not return the DM drives?
